Question about Xact Communication XTR1 SIRIUS Radio Receiver
Will not pick up signal
My shows "ACQUIRING SIGNAL" but the signal is not picked up by the unit. I have checked all connections and used different antenna positions to see if that would solve my problem. My wife also has a unit and it worked perfectly in my car using my antenna and hers, so I'm confident that the antenna is not the culprit. I contacted SIRIUS and they re-sent the signal to my unit, still no response, same display. While on line with SIRIUS, I reset the unit back to factory default which did nothing either. I can't imagine what could have happened, the unit worked flawlessly until now with no problems at all. Any suggestions you could provide would be greatly appreciated. Thanks in advance Larry Gillespie
  • Anonymous Feb 04, 2008
    I just cancelled my Sirius service because the "acquiring signal" was all I could get for the past 2 months. It is most certainly a problem caused by Sirius and not your hardware. Sirius customer service was awful and clueless. I miss it but the continued problem with no help from Sirius gave me no choice but to dump them.
  • Anonymous Mar 19, 2009
    Ditto. Started 'acquiring signal' message in November after two years tuning great. Two antennas have not changed the issue. Tried all the resets and took the unit all down to bare bones after Sirius customer service gave me ZILCH but the old buy another antenna. Then out of the blue in February the thing came alive for ten minutes and went back to acquiring signal. Since then I have been fishing several times and it dowsn't work as a lure or weight.
    Champion:
  • 277 Answers
My guess is that in some point u droped it or something like that the problem sounds like a crystal fault and with u cannot do nothing before u send it to fix try opening the device and see if the wireing of the antenna R fine good luck windman
Posted on Feb 13, 2006
SOURCE:
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
Cannot locate saltellite or Acquiring satellite
The error means it can't pick up valid GPS signals. In other words, bad reception.
Has the unit ever worked? Does the unit have an internal or external antenna? Are the batteries fully charged?
Try the unit outside with clear view of sky instead of in the car. This will give it the best chance of picking up a GPS signal.
If it still doesn't then suggest something broken inside.
May 20, 2009 | Garmin nuvi 200W GPS Receiver
Sirius Stiletto 2 constantly "acquiring signal"
This is an odd fix, but I read it yesterday after having the "Acquiring Signal" issue for a week. I put it in the freezer for 30 minutes, brought it back to my desk and now it works. I don't know why or how, but I am happy.
May 04, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Magnavox
You may need a stronger antenna or your neighbor may have only a VHF antenna and most of the digital channels are being broadcast over UHf. . First, though, check the antenna connection as if they are dirty, they may be lowering the signal strength (these are the connections at the antenna). Check antennaweb.com for the angel to put the tv antenna at to pick up the most channels. Internal antenna work very poorly. I have been having no problem with my outdoor UHF/VHF antenna, it picks up the same amount of channels in analog and digital.
Oct 05, 2008 | Philips Magnavox 20MS233S 20" TV
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is indoors, it may not acquire satellites.
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Xact Communication XTR1 SIRIUS Radio Receiver Logo
813 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
