Apple iPod nano Logo
Posted on Sep 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipod won't sync to Itunes
Hello, I am having an issue with my Ipod. It gives me an error code when I plug it in saying that it cannot sync because the files or directory has become corrupt and unreadable. Someone on the Apple site suggested (to someone else with a simular issue) that this could be caused by locked files in the directory. I am good at following step-by-step instructions, but have no clue how to even access this directory so I can *see* if anything is locked. Any ideas? Thanks!! My laptop recently crashed an the hard drive was completely wiped so I had to buy a new laptop. I managed to get my music from my iPod onto my computer, I then downloaded iTunes and added the folder to iTunes. Now, however, my iPod won't sync. I don't why this is, or how I can fix it? Any ideas? Help would be greatly appreciated!
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Sep 19, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2174798
Points
14133
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
2helpful
Error code 1140
Yes, I have had this problem. First, I would disable the automatic sync with the iPod and ITunes. You can do this by going into preferences in iTunes. Download the latest version of iTunes by checking for an update. Then click on your iPod in iTunes and restore the iPod to its original setting. This will erase the whole iPod. Then you can sync it with iTunes again. That should fix the problem.
3helpful
2answers
Does your ipod actually work or no?
if it works put it in disk mode by pressing the menu and center buttons and holding until the apple appears and switching to the center and play buttons and holding until the check mark appears.
then plug it in the the usb and see what happens.
if it mounts to itunes try and restore. if not go to my computer and see if it is there. if so right click on the drive and format...not quick format use full format.
then repeat the steps before until you get it mounted.
more than likely you have a virus and the virus is not letting the restore program delete it.
7helpful
6answers
Ipod touch stuck in itunes recovery mode. message, error 14.
JUST SHUT IT OFF AND THEN CONNECT YOUR USB CABLE TO YOUR PC AND IPOD, THEN HOLD THE HOME AND POWER BUTTON UNTIL YOUR SEE I TUNES ICON WITH THE USB CONNECTOR RIGHT UNDER IT, WHEN YOU SEE IT LET GO THEN IT'LL SYNC INTO ITUNES AND JUST FOLLOW THE INSTRUCTIONS.
RATE ME PLZ.
you should have updated your ipod software in piracy please try to load an original one
Because you have all your music already backed up onto your pc you can safely erase your ipod. Have you already tried to do a restore on it yet. To do this connect the ipod to the pc and in itunes on the ipods main screen click the Restore button, then choose the bottom most option if it gives you any. If it says to erase the device anywhere, all the better, select that one.
If that doesn't work, assuming you're on a pc and not a mac, open 'My Computer', right click the ipod, select 'Properties' then erase it as you would any harddrive. Once you have done either of these you can resync it in itunes.
All the best
Sean
When you wiped the old computer and then reconnected to the new computer, it reformatted the player, causing data corruption. I would try all five of these suggestions, but first try uninstalling and reinstalling all Apple/iTunes software: Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Hey try plugging in your ipod and then go to the ipod thing and hit restore ipod and then once it is done then try to sync your ipod
give it a soft reset if this is not solve the prob
give it a firmware upgrade
u can find the upgrade tool and the F/W
on ur website support area
plaese rate this post!!
maybe - just maybe - if you plug it into your computer and then, if a mac, do the 'get info' bit and look for the info regarding if a file or device is locked.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
