SOURCE: navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
SOURCE: Would some on please help show how to reset my
looking with the screen towards you, on the right hand side of the gps near the top is a reset
SOURCE: Navigon 2000s I cannot reset the Navigon 2000s
Well after many emails to Navigon I got the fix for my 2000s What you have to do is download the 1.2 version software for the 5100 install it on a 2GB micro SD Card. Put it in the slot and turn it on. You will have to regester as if you have a 5100 but it will work. The reason you have to use a 2GB card is the maps are to large to go on the internal memory.
SOURCE: Navigon 2100 - need to open the case to replace
To open the case you will need a very small flat screw driver to pop off the back of the case (be very careful as the clips holding it together are very small). You will then have four small phillip screws to remove, so that you can remove the front of the case. To remove the circuit board, there will be two very small phillip screws holding it in place once you've remove the front case.
