SOURCE: 2701HGB modem - dsl light flashes red
if all the lights on the modem are Green then it means there's no prob with the hardware. just make sure that you're going to use the right WEP key or wireless password. the network name is 2wirexxx, the X is the the last 3 numbers of the SN which can be found on the bottom of your 2wire 2701HG-B.make sure that your wireless switch is also turned on of course. the wireless light on the modem will lit if it is connected
SOURCE: Recently I subscribed ATT DSL Service conflict IP Address
vonk gudda dengichukora looudekebaal
SOURCE: I have a 2wire 2701HG-B modem and ATT DSL srvice.
I had the same issues with SaskTel in Canada, with the same router. It was a downstream line issue. Actually, I had the problem twice with 2 separate causes. I'd check the continuity of the lines from the punchblock (where the service enters the house) to the wall panel that you are plugging the router into. There may be a bad pairing somewhere in the wall from corroded wires, rodent damage, heat etc... and simply swapping the pairs at the block and the wall may fix the problem. That being said, both fixes from SaskTel came at the local junction box, once from a tech bumping one of my lines off the block and another from a second high-bandwidth line being connected into the same pairing as mine on the main line.
So, unfortunately, if its not in the wall...you'll be pulling teeth with AT&T for a while.
