SAMSUNG 3310 GAMES LIVE THEMES JAVA APPLICATIONS WAY TO INSTALL GAMES JAVA CODE
For SAMSUNG GT-S3310 single player , multi player games and living world themes visit:
www.3310goodies.blogspot.com or href="CLickHere">http://www.3310goodies.blogspot.com">CLickHere ************************************************
*****Please Do it at your own risk:****
STEP1:
Uninstall Samsung PC STUDIO 3 , if you have downloaded and installed. since no one gets installation CD within the package.
STEP2:
Uninstallation of PC studio won't delete the drivers installed. Go to Control Panel--> Add remove Programs-> uninstall each and every mobile driver of Samsung. After doing it , restart your P.C.
STEP3:
You need Mobile 1.0 drivers. You can download it from the following links. Use only 1 link. Multiple links are provided so that if one fails , other is up for you. It is a 1.20MB .rar File. Links for V_Mobile1.0Broadcommdriver.rar are:
Link1: Ziddu hosting link:
http://www.ziddu.com/download/6626837/V_Mobile1.0Broadcommdriver.rar.html or Click Here
Link2: Easy Share link :
http://www.easy-share.com/1907898141/V_Mobile1.0Broadcommdriver.rar or Click Here
****if no hosting link works , mail me at
[email protected]****
STEP4
There is a file "setup" in the folder which you get after extractaction from V_Mobile1.0Broadcommdriver.rar file . Run Setup and drivers will automatically installed. Now after this process, attach your mobile with Pc. When you will attach mobile to PC , Mobile will prompt to select one from 3 options
1. Samsung Pc Studio
2. Media Player
3. Mass Storage
If it doesnot ask for these options , go to Menu-->Setting(#)-->Phone settings(4)-->PC Connections(5) and select ASK ON CONNECTION and reconnect the phone to pc.
Select Samsung PC studio in this step
STEP5
You need FILE EXPLORER(pc version) for your phone and 1 java game to test it. You can download both in 1 package from the following links. Again there are 3 links , use 1 only. Other is added for your convienience
FE and Asphalt 3 from gameloft.zip (513 KB) Will extraxt in 1.45 MB
Link1:
http://www.ziddu.com/download/6627016/FEandAsphalt3fromgameloft.zip.html or Click Here
Link2:
http://www.easy-share.com/1907898115/FE and Asphalt 3 from gameloft.zip
or Click here
Link3:
http://www.filefactory.com/file/a0b1fb0/n/FE_and_Asphalt_3_from_gameloft_zip or Click Here
STEP6
Place folder Asphalt Urban to your C:\ drive or any other drive. Don't put it on desktop. Remember the path where you have put Asphalt Urban Folder
STEP7
Run TK File explorer by double clicking TKfileexplorer2.2.exe. There is no installation. Tk File Explorer wil open. See image below.
STEP8
This step is crucial and involve hit and trial and luck. open TK File(ur phone should be attached to usb and in pc studio mode). Now near to yellow question mark(see pic) , there is a setting button. click it it will ask for PORT.
If no port is mentioned , add manually in add port. To manually do
1. Write COM4 OR COM5 OR COM6 OR COM7 IN CAPITAL LETTERS IN COM PORT
2. Set Baud rate to 115200
3. CLICK CONNECT BUTTON
* Most of times it connects from above mentioned ports. try from port 1-10 if not connecting. Even one guy connected at port 16. So please at least try up to COM 16.
its hit and trial in some cases.
But it will connect for sure. Do repeat your process.
if problem occurs mail me at
[email protected] This video corresponds to step no 8 only.
Click the image to get it enlarged
STEP9
Transfer Asphalt urban folder to
EXE---->>>JAVA------>>games (you can delete the locked games from here)
Do ensure that files are successfully transfered by exploring your phone with Tk file explorer.
STEP10
It is not done yet. De-attach your phone from pc. Type *#6984125*# from your phone. A menu will pop. Go To INTERNALS. A master code will be asked. Type *#9072641*# Go to Storage Settings select Update Java DB.
(VISIT
WWW.3310GOODIES.BLOGSPOT.COM FOR LIVING WALLPAPERS, EA AND GAMELOFT GAMES AND MUCH MORE RELATED TO SAMSUNG GT-S3310 METRO)
Hurray you are done. Enjoy your game. Repeat steps to install other games.
For animated themes, other games and multi player games , tips and tricks do visit again 3310goodies.blogspot.com,
Animated themes will move you like crazy.
