Jura Capresso C1300 Coffee Maker, Espresso Machine Logo
Posted on Aug 19, 2011
The solenoid valve needs to be replace - part nr. U35D , 120v/60Hz, 8VA, manufacturer ACL Italy , art. no. 24799A. Please let me know where I can buy a replacement part - thanks! Adina
Arun K A
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 01, 2022
Arun K A
Contributor
Level 1:
Answers
Questions
0
Helped
495
Points
You can visit https://rotexautomation.com/ for your requirements. they are the largest solenoid valve manufacturer in India and have a supply chain all over the world
mjboon
Level 1:
  • Posted on May 31, 2018
mjboon
Contributor
Level 1:
Answers
Questions
Helped
495
Points
Https://www.betavalve.com/Product-Detail?prodref=U35D&category=144
1helpful
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
There are universal power supply units available that come with a variety of interchangeable ends and switchable polarity, current and voltages. However, if one of these will fit your particular needs I have no idea or indeed if they are available in your country. Try eBay or Amazon. I hope that is of some help.
My washing machine,only on spin cycle,kicks breaker off,it does'nt kick breaker off on any other cycle?
yes in spin cycle the drain valve solenoid is open (on) how else would it get rid of water it spins out , id look real careful at this device I'll bet there's some sort of visual evidence of a problem there (rust.heat marks, wet )
2answers
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this
120V ~ 60 hz 10.5 amps or
120V ~ 60 hz 10.5A or
120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)
120Volts ~ 60hz 1260w or
120Volts ~ 60HZ 1260 watt
120V stands for normal operating voltage
"~" means ac current
60 herzts stands for how many cycles
So if your unit shows only amps, it's really simple to figure out wattage
take the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 watts
W = V * A
and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it
AMPERAGE = VOLTS / WATTAGE
1helpful
Our Transformer became very hot a couple of days ago and eventually turned darker brown across the mid-section of the transformer within an hour. We disconnected the unit and want to know if this is...
ours did the same thing with the darker area in the middle of the front of it. My andyman tested the battery and wire and all is fine so ordering a new transformer.
I need to know how to install a cellanoid in my Whirlpool Duet washer Mod # GHW9150PW4 is there a place to get the instructions?
Are you meaning the Water Inlet Solenoid Valve??????
If yes .... you need to know if your W/P Duet GHW9150P Front Load Washer really has a bad Water Inlet Solenoid Valve for the Hot and Cold water. This valve is where the Hot and Cold water hoses connect to the rear of your washer on the upper top left side in the rear as you are facing the washer. In my opinion it is highly unlikely that your Water Inlet Solenoid Valve is bad....but it is possible. Sometimes the filter screen in the inlet(s) of the Hot & Cold water valve can be stopped up with dirt, sediments, etc. If you turn off the water faucets and remove the Hot & Cold water hoses from the washing machine... you will be able to see the screens...if they are stopped up you can remove them with a small screw driver and clean them and reinstall them.
Hook up your hoses and turn on your water supply Hot and Cold faucets.
Here is a quick test procedure that you can do to verify the operation of the Water Inlet Solenoid Valve.
Verify that your water hoses are hooked up and the water faucets (Hot & Cold) are turned on.
Unplug the washer's 120Volt AC power supply cord from the electrical plug on the wall.
(1) Remove the top cover...There will be three screws on rear area of the cover: Left - Middle -Right.
(2) Once the top cover is removed...you will be able to see the Water Inlet Solenoid Valve...just follow the Hot & Cold water hoses from the wall to your washer. Usually the water inlet solenoid has a blue plastic housing assembly with (2) separate push-on or pull-off quick disconnect electrical connectors. One connector pair provides 120volt AC to the Hot water solenoid and the other connector pair provides the 120volt AC to the Cold water solenoid.
(3) Remove the push on or pull off quick disconnect electrical connector to one of the water inlet solenoids..It does not matter which one at this point in time.
(4) You will need an electrical 120v AC Test Cord. You can make this from an old lamp AC power cord or and old 120v AC Extension Cord. You will need two alligator test jumpers or leads (Radio Shack has them). The end of the test cord that plugs into wall is not to be modified. The other end of the test cord will have to be modified in order to conduct this testing. Strip back the insulation to reveal the two leads that will carry the 120v AC power. You should have one black lead (120v AC HOT) and one white lead (120v AC Neutral). Connect (1) alligator test lead to the black lead and insulate with electrical tape as necessary and connect (1) alligator test lead to the white lead and insulate with electrical tape as necessary You now have your 120v AC Test Cord ready. If you have a VOM test meter..you can connect the VOM meter to the two remaining alligator test leads. Have your VOM test meter set for AC Volts and on a scale that will measure 120v AC. Plug in your test cord to the 120V AC wall power. If everything is OK your meter should read approximately 120 Volts AC.
(5) Unplug your 120v AC Test Cord from the wall power.
(6) Connect your 120v AC Test Cord to your Water Inlet Solenoid Valve electrical terminals.
See Step (3).
(7) Plug your 120v AC Test Cord into wall power. If the water solenoid valve is good you should hear water surging thru the water solenoid valve. If you do not hear the water running thru the valve you can verify if the 120v AC is getting to the valve with your VOM. It should read 120v AC. If it does read 120Volts AC at the terminals of the valve and you do not hear the water then the valve is probably defective: Either stuck shut and won't open or the solenoid coil is open (Bad).
(8) Unplug your 120v AC Test Cord from wall power.
(9) Disconnect your (2) alligator test leads from the solenoid valve and re-install the electrical push on connectors that was disconnected in Step (3)
(10) You can now repeat this test on the other side of the Water Solenoid Valve (See Step 3).
(11) If both sides of the Water Solenoid Valve check out good...then your Water Inlet Solenoid Valve is good. If it does not check out then replace it.
(12) If your Water Inlet Solenoid Valve is good...then ....unfortunately, there is a good chance that the CCU module is bad. The CCU module is in effect a computer control unit and controls the overall operation of the washer. The CCU module will cost approximately $150.00
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
I need to replace cold water solenoid valve.
Good day,
This tutorial doesn't address the water valve directly but it does get you to the area you need to change the valve. Use only the part you need.
http://www.youtube.com/watch?v=WLPGs2UMUJc&NR=1
2helpful
2answers
I need to know the AC/CD adapter part number for the Vector 450 AMP Jump Start System so that I can get the correct one from CNAweb.com
5140045-42 AC Charger with Small Jack 12v 500ma 2.5*5.5mm. For units Manufactured with date codes before October 2006.
Power supply specs
Manufacturer - 2WIRE
P/N - 2900-800007-000
Model - SAL115A-0525-6G
SWITCHING ADAPTER
Input - 120V ~ 50-60Hz 400mA
Output - 6V 2000mA
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
