Make sure that the needle is fully up first and raise the presser foot. To access the bobbin, you need to remove the flat bed attachment that is at the front of the machine. This just rotates up and off the machine. Next rotate the shuttle cover down from the top of the cover. Now you can pull out the bobbin case towards you by the latch. This piece goes across the center of the bobbin case and to the right. Now you can remove an empty bobbin (if needed) and put the wound bobbin into the bobbin case to replace the bobbin.
For this procedure, the pictures in the manual may be clearer than the written description. See pages 14 and 15 (16 and 17 for the PDF) in the manual. Brother currently has the manual here:
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_LS_2125i_EN_1628.PDF . The LS-2125i support is here:
http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=LS2125i . Click on the Manuals & Documents page. Most Brother manuals and other documents can be found by searching here:
http://www.brother-usa.com/Support/ .
I hope this helps.
