SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
SOURCE: well every time I pull the throttle I can hear the
use a test light and see if the motor gets a hot wire when you pull the throttle, if it does then its a bad motor, if not the throttle is bad. make sure to inspect all connections before beginning to insure no other possabilities.
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
SOURCE: Battery light shows full charge
In that case the power doesn't reaches the motor from the battery - check the key contact and its wires for bad contacts.
