Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
SOURCE: KitchenAid Dishwasher KUDS01IJ will not
couple things you can try first hold down cancel for ten seconds this usually cancels the cycle and puts the unit in the drain function or you can try hit high scrub and than energy saver and repeated the same after a few seconds or if this also doesnt work then you could also try shutting of the power by way of the breaker for 5 minutes which usually causes the controler to reset if none of these tests work message me back and we can perform other tests also how many times are the lights blinking if its 3 times then these tests should correct the problem if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
SOURCE: DISHWASHER
It sounds like a faulty console panel. I will need the model number to diagnose it any better. Open the door and the model and serial number tag should be on the side of the cabinet, usually on the left. Respond back with it and we will see if we can walk through the problem. Thanks/Mike
SOURCE: My KitchenAid dishwasher model KUDM01TJBS0
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
SOURCE: Runs 2 minute rinse only
cloged airgap ?
unit may be in showroom mode
remove kick panel, retrieve service manual from kick panel
put unit into service test mode. let it run tests. it should reset
