SOURCE: Problem with ice maker on Whirlpool fridge
2 things, Usually when you disconnect the water the rubber seals stick to the plastic walls of the inlet valve housing when the water evaporates. This is the most common cause.
The other is the module linked below goes bad. If you remove the white cover on the front of the ice maker most times you will see a tab broken off of the larger gear in the center. A picture of the module is linked below.
Ice maker module.
SOURCE: model LRTX18311WW Water on the bottom
i use a basting syringe filled with clorine bleach..........works for me.
