SOURCE: i have recently upgraded the ram and cpu in my
Ok first of all perform a Microsoft update, when its done i suggest you download a system cleaner, java and the latest Abobe flash player.
Get Ccleaner here, use the cleaner and the registry cleaner and back up to the registry and restart your PC >>>
http://www.filehippo.com/download_ccleaner/
Flash player here >>>
http://get.adobe.com/flashplayer/
java here >>>
http://www.java.com/en/download/index.jsp
remember to restart your PC after using Ccleaner.
post back if its still the same.
Good luck and thanks for using FixYa!!
SOURCE: solusyon
I-download ang cCleaner at patakbuhin ang registry cleaner bahagi ng programa. Ito ay maaaring ayusin lamang na error. Dito ay ang lokasyon para sa pag-download,
http://www.ccleaner.com/ccleaner-20
Inaasahan na ang maliit na boses sa iyong ulo ay masaya at na ito ay gumagana ng mabuti para sa iyo.
Paki-iwan ang rating, salamat mabait
SOURCE: No boot after putting 2 Gb additional in Mb
try to reset cmos after putting 2 -1 gb rams(pulout power cord,and change clear cmos jumper to clear for 10 secs,or just remove motherboard battery for 30 secs,post mb info if no luck with cmos clear
SOURCE: I am looking for an ACER 8i945 AE Mother board
hi this is kamal
you can put 1 gb ram easily
Testimonial: "thanks that is good to know"
SOURCE: Can I upgrade my 2.8 Ghz CPU with the 3 2 GHz dual
as long as the socket is exactly the same as the processor you are trying to upgrade to you should be good. As far as memory goes you can use a faster ddr2 chip but you have to find out what the maximum capacity is on each slot. Most newer computers can support 1gb+ per slot. Always make sure you install ram in pairs and in the proper slots.
