SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Jabra BT150 No power
Make sure the charger is in right. If you put it on wrong you will get a faint blue light, when it is in right you will get a BRIGHT BLUE LIGHT. It WILL NOT charge if it is in wrong.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for manual
SOURCE: Jabra BT150
Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
Pairing code 0000
DO NOT PRESS (-) key
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
Manual is incorrect.
Jabra must be 'on' instead of 'off'.
Then press '+' and 'on' button till blue light stays on.
SOURCE: make jabra bt 150 discoverable
within connections settings on your phone your jabra will always be discivered if you have set your bluetooth within phone to be on all the time, when you switch on head set it will be automatically picked up by your phone.hope this helps
