We've never dealt with snom wireless adapter but the CS70 and HL10
lifter is a popular set for your phone. there are a couple of things you
can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is
set correctly. Most phones work on setting #1 (never between numbers)
3.
Echoing is usually caused by an improper mix of incoming and outgoing
volume. With a friend listening in you can make broad and minor
adjustments for both (incoming: back of base (1-4) and +/- on headset;
outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
