Washer fills, washes but won't spin. washes back and forth just no fast spin. Since it does not spin , won't drain either. Washer fills, washes but won't spin. washes back and forth just no fast spin. Since it does not spin , won't drain either
This can happen when the drainage pump is faulty.
Hope that helps!
Http://www.repairclinic.com/0088_11_1.asp
This link will show you what is wrong when it isnt spinning or draining. If you need any further assistance let me know. If you have a moment to accept and rate my solution accordingly I greatly appreciate it.
Thanks,
Lee
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Check the drain hose, probably it is not spinning because the drain pump is faulty.
Do you get any error code?
First unplug the power cord for 10 or 15 minutes to see if reset can clear the problem.
If it does not run it can be stopped because drain pump is faulty, or because of the door switch.
If cycle is stopped ckeck the door switch, that is not stuck.
See this link here
If you need to call a technician you can use the number listed on the repair manual.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer fills, washes but won't spin. washes back and forth just no fast spin. Since it does not spin , won't drain either, Need step by step solution please.
