SOURCE: Toner low indication
Take out toner and shake up down . And put it again. may it will help you . Else let me know.
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Try removing the toner cartridge and putting it back in place.
Try also unplugging power cord for ten minutes, and check if this clears error message.
Inspect the printer for foreign objects, or paper stuck inside.
If this does not work, it is a faulty drum.
SOURCE: Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
A 94x.xx TMC Error indicates that the printer has failed to detect the Toner Metering Cam for a specific cartridge. This error typically occurs when the cartridge or developer are misaligned or incorrectly seated
Please click on the link http://bit.ly/ozldpC to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
