Where is leak coming from?
From the pipes or from bottom of disposal?
If leak is coming from tubular drain pipe or around dishwasher connection, then clean out disposal and repair connections.
If leak is at bottom of disposal, then disposal is probably rusted out and needs replacement.
To solve high water issue and leaking pipes.
Loosen 2 nuts on P-trap and trap falls loose. Then remove tailpiece that connects to side of disposal. Hang rag over opening on side of disposal so water is directed downward, then turn on water and disposal and flush out the clog. Clean trap and tubular drain, and then reassemble.
I wrote ez disposal replacement steps, that also show how to take apart and reassemble tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
