What is the Compression supposed to be for a 1987 Toyota Pick up 22R with carb, 4 cyl.???
A new engine would be about 180 psi for each cylinder. As the miles add up and wear occurs, compression will get lower. The important thing is that compression is even and balanced-lowest compression reading should be within 75% of the highest cylinder's compression. Some Toyota engines had a minimum allowable compression of about 135 psi, but if compression is balanced, you could have average compression as low as 125 psi and engine would still run good, some loss of power but still acceptable, and oil consumption would not be that bad.
If cylinder compression is below 120 psi as an average, you should be looking into a rebuild event-rings and valves need attention. If any cylinder is below 100 psi, it may not even fire, certainly will produce no power, and could be a head gasket failure, very worn rings, or valve problems.
Remember the important thing is to find compression readings that are very close to each other. I have an '87 Sentra with 75,000 miles(true!)-lowest comp. is 160, highest is 165 psi-runs great, good power. Also a '79 Datsun pickup (with god only knows how many miles-about 200,000 maybe). Compression is about 125-135 psi, fairly well balanced-noticeable loss of power, very little oil burning, still runs fair to good-dependable, at least.
That should give you an idea of what to look for. Good luck.
