Question about Toshiba 43H70 43" Rear Projection Television
TV auto shut off-power indicator light blinking-won't turn back on
While TV was on, working fine, it just shut off. Power indicator light is blinking - hit the power button on the remote, power indicator light then blinks faster, but tv does not turn on. Hit the power button again on the remote, power indicator light is on steady, tv does not turn on. ???
  • 3 more comments
  • needfixen Nov 23, 2007
    my tv does the exact same thing. if i unplug it, plug it back in, turn it back on, it will work for a very short time(1-3 min). i did vaccum all the dust out. i know it has a power down system to save it from further damage if something overheats.
  • Anonymous Mar 22, 2014
    Power is getting to the TV with the red standby light blinking but tv will not turn on when using the remote control. Have replaced batteries in remote but still not working.
  • Anonymous Mar 25, 2014
    Is there a kit or something to purchase to fix the problem?
  • Anonymous Mar 30, 2014
    Turn ac power off to put install fan turned ac back tv wouldn't turn on cable receiver did
  • Anonymous Mar 31, 2014
    The power button on the remote does not work. But all other functions on the remote work fine.
    President:
  • 3,130 Answers
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Posted on May 14, 2006
I am also facing the problem like this, TV power indicator blinks continously. TV doesnt come to normal
Posted on Feb 05, 2008
Try checking the projection bulb.Should be an axess panel on side of tv. Be sure the tv is cooled down and unpluged from the wall.Bulb held in with 2 screws. don't touch the lens of bulb.You will be able to see if bulb is good.
Posted on Feb 07, 2007
We had this problem on our tv. It would drive us nuts. If you unplug the TV from the wall, it would reset and be fine. Strangely enough, we moved and since it has been in the new house, roughly 3 months, the problem has never happened again.
Posted on Feb 04, 2007
I HAD A CONFERGENCE ERROR AFTER SEEING THAT I NEEDED TO AUTO TUNE. NOW THE POWER BUTTON JUST BLINKS. I TURNED ALL POWER OFF TO TV ALL NIGHT, THEN TURNED ON POWER. JUST A BLINKING LIGHT NOW . ANY HELP PLEASE. KEVIN MODEL 42H81 TOSHIBA
Remote is working correctly - tv was unpluggled and then plugged back in - everything working correctly...
Posted on Jan 12, 2006
My TW40F80 (10 yrs.old) kept going out and power light blinking.  When turning the power off then on did not bring it back any more, I had service.  The tech 'rebuilt the convergence circuit' with a $70 part from his truck.  Works fine now, but total cost was $99 service call, $75 part and tax and a whopping $229 labor for about 45 min. of working on the convergence circuit. TV works great $404 later.
Posted on Jan 11, 2008
    Problem Solver:
  • 29 Answers
1. make sure the power card is plugged in, then press POWER. 2. the remote control batteries my be dead. good luck :-)
Posted on Jan 11, 2006
6ya staff
SOURCE:
Tv just went off in use. Power light blinking, will no turn back on
Set is in shutdown as a short somewhere.
If model indicated here is correct someone has to open it and check voltages in power supply first.
Apr 01, 2012 | Toshiba 36AF43 36" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
RCA D5210 TV will not turn on...
Common problem on this tv.
Replace capacitors in power supply.
2.2uf 100V and 15uf 100V and 470uf 25V.
Thank you
Aug 04, 2009 | Televison & Video
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Toshiba 43H70 43" Rear Projection Television Logo
1,468 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
