AMD 2.3GHz  Phenom X4 Quad-Core 9650 AM2+ 3600MHz HT 2MB L2 HD9650WCJ4BGH Logo
Anonymous Posted on Aug 18, 2011
Can AMD Phenom X4 9650 Quad to use in motherboard Asus M4A78T-E ?
Tapas Basu
Level 2:
  • Expert 80 Answers
  • Posted on Nov 23, 2011
Tapas Basu
Expert
Level 2:
Answers
80
Questions
Helped
23096
Points
153
Yes your motherboard supports AMD Phenom X4 9650 Quad. However you need to make sure your BIOS verson is greater than 1503. if not you need to upgrade your BIOS.
Caution: Update your BIOS if its absolutely necessary and at your own risk. Wrong move may spoil your motherboard.
2answers
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
2helpful
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Hi, I am having an issue where upon waking my computer from standby mode (S3), there is no display and fan speeds become irritably loud and fast. I have no choice but to turn off the power from the back of...
if you did not used heat sink paste between the heat sink and the cpu unit, that, will be you problem initially
the paste is used to exclude any air and gaps between the cpu back and the heat sink and makes a perfect heat transfer medium
cpu units will hit critical temps within seconds if the heat is not being transfered correctly
1helpful
Sounds like a procie problem.
Check your processor's heatsink, if it really sits flat on your processsor.
Try to replace with another processor, take note of your socket if that is for the board's requirement.
Put a new heatpste too.
Then tell us the effect.
Thanks for using Fixya!
Amd processor upgrade
The M3N78-em mobo doesn't support AM3 processors. It is an AM2 / AM2+ platform. A wonderful GPU for you would be this. http://www.newegg.com/Product/Product.aspx?Item=N82E16814102858
If you have any other questions please write back in this thread. I will be happy to help you through your computer upgrade.
How to set asus montherboard bios
keep pressing del as u start the pc u will see the bios
as far as GPU is there u can do it from the bios for overclock related thing and for other thing u can do it using the windows
3answers
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
