SOURCE: New magnetic molding on refrigerator not working.....
Use a hairdryer all around the gasket to soften the vinyl then "twist" the door until you get a good fit. Leave the door shut and switch to "cool". Don't open the door until the gasket is at room temp. Tighten screws all around in random order. Repeat if necessary. In severe cases it might be necessary to "shim" the hinges out just a bit with cardboard.
SOURCE: Need to remove plastic molding in back of 2003 GMC Yukon
Go to the library and look for the Factory Service Manuals (not Hanes or Chiltons or Motors) for your vehicle. You might want to call the library first and ask if they have them, or can they order from the repository library. These are what the dealers use to repair and troubleshoot all aspects of these cars.
SOURCE: remove the lower window molding on2000 durango
For the lower belt molding?
1.lower glass
2.Lift corner of weatherstrip upward and remove weatherstrip from outer door panel.
SOURCE: lower body side cladding or molding im trying to find the piece on the front passenger door
I am parting several 93-97 Intrepid, Intrepid Sport, and Intrepid ES....which part of the ground effects do you need, door part(which door) or the rocker panel part (front or rear, left or rght)....email me at [email protected]
