On your oil tank, there are three hoses. The hose that comes off the lower fitting goes to the outside fiiting on the top of the pump or to the center fitting of the pump top plate. The oil comes out of the inner fitting on the pump and goes to the oil filter. It should to to the outside holes of the filter. The oil leaves the filter though the large hole in the center and returns to the tank to one of the fittings at the top of the tank. The other fitting at the top of the tank comes for the engine case just above and to the inside of the oil pump. On the lower backside of the oil tank is the oil drain hose. If you're unsure which fitting on your oil pump is the inlet and which is the outlet, squirt a bit of oil into each fitting until it's full. Then press the start button or rotate the engine in it's normal direction of rotation and watch the oil. If the oil is sucked into pump, that's the inlet. If it's pumped out of the pump, that's the outlet. Sorry I don't have a picture. There is a drawing in the service manuals.
Good Luck
Steve
