HTC F3188 Smartphone Logo
Posted on Aug 18, 2011
I am using HTC smart f3188 . My Network provider is Airtel ( sim is Airtel) but the phone is connecting to Vodaphone In network. I cant not calll but I can receive other calls. I have tried My SIM with other Handset and its working fine. But it snot working in My handset . I Please suggest how to solve the problem .
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Aug 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
18
Questions
0
Helped
2122
Points
56
You can contact the service provider............
  • Daryl Middleton
    Daryl Middleton Apr 01, 2014
    I've contacted provider they want to give me another phone with the same software on it..
3helpful
2answers
After unlock country code my HTC f3188 shows "Smart card invalid" what is the problem and how can i solve it?? pls. give me solution
you can Unlock your HTC F3188 with imei unlock code. it is very simple and eaisiat way to unlock your HTC F3188 . get your HTC F3188 Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
1helpful
Due to unlock country code it shows "smart card is
It shows invalid Sim card means it locked to Network,You need to unlock it...You can get the Unlock code from here
Theunlockspot.com and unlock it from Network lock,then you can use any GSM Network Sim card.
I need the puk code for my htc smart f3188 phone
contact ur network service provider....
I am not able to make out going calls from my htc smart f3188. every time i tried to make call it shows ENDING CALL.........
Try resetting the network settings. Call your provider because this is more likely a network issue. Or you can do a hard reset.
1helpful
2answers
Im using htc f3188 phone and im using idea as network . i rechaged my phone with 97 net pack. but no body is able to do net setting. plz help me out plz plz plz
Use this address to get your settings info:
http://www.flexispy.com/Mobile%20APN%20Setting%20to%20use%20GPRS.htm
Connecting to the Internet When you turn your phone on for the first time (with the SIM card inserted), it should connect automatically to your mobile operator's data service. You can start browsing the web straight away.
Checking your current data connection settings Your phone has been set to connect automatically to the Internet through your mobile operator's data service. If you don't get a connection automatically, check your network connection settings.
  1. From the main Home screen, press MENU, and then tap Settings > Wireless controls.
  2. Make sure that Mobile network is turned on.
  3. Tap Mobile network settings, and then check the following:
    • Automatic setup is turned on.
    • The name of your mobile operator is displayed in the Network operators item.
    • The right mobile network is displayed in the Access point names item. If it's not the right network, see your phone's user guide to find out how to add a new access point.
Turning the data connection off You can turn off the data connection to help optimize your phone's battery life or to save money on data charges.
  2. Turn the data connection off by tapping the Off/On switch of Mobile network. (Tap this switch back on if you want to connect to the Internet again.)
The phone is a SMART F3188 unlocked and I took it to a virgin mobile store where they proceeded to check their info. I was then told that it should work so I bought a SIM and switched my blackberrys plan...
it may be due to network lock, contact service provider , else you can get unlock codes here http://www.onlinegsmunlock.com/
you need to specify the phone model and network provider,you can choose the plan regarding the requirements
2helpful
I am accessing internet in my HTC smart f3188 mobile using Airtel Gprs pack.I want to access the same in my laptop .Can you please tell the software i need to install in my pc to connect internet to pc...
i am accessing internet in my HTC smart f3188 mobile using Airtel Gprs pack.I want to access the same in my laptop .Can you please tell the software i need to install in my pc to connect internet to pc through modem connection
2helpful
HTC Touch Cell Phone-network lock
i've a HTC Touch Cell Phone, i had purchase the same with airtel connection now i want to use another connection like or Idea but heandset gives a errer " network lock pls give network code" Plsssssssssss help me
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
