If you can see the screen partially you can get the code SN and SNID by the following route
Comment back if you can't get it this way.
If you have a password on the tablet, you can plug in a USB keyboard and type in your password and press enter to unlock. Then press "Menu" + m to pull up the settings and follow the above steps to get your SNID and SN. Menu is the key in between the alt and Ctrl to the right of the spacebar
thanks for your advice but none of the above is what im talking about. I do have the box for the tablet which has both codes, my only problem is that the codes i use aren't valid on the Acer support website...(USA) i need the codes so i can send in my tablet for a repair.
Unfortunately I don't think people would feel comfortable (me included) giving out their own device SN and SNIDS as this would cause problems if they/me wanted to have their own devices serviced. I will point out the reason, in most cases, why companies will not service a foreign country device. It is simply that devices tend to have slightly different form factors and as a result US parts may not work in European devices.
Your best bet would be to contact Acer directy.http://www.acer.it/ac/en/US/content/cont...
Also the (USA) website could be setup to take USA SN numbers, yet contacting them they maybe able to place the service order that way.
Best of luck omari
the touch part of the screen is broken so i cant unlock it i need some one's serial and snid(USA) number because my tablet was bought in a different country.
no numbers that i can see model No81-710
