ts4000 Bosch motor wiring (post #210578, reply #6 of 7)
by emils01 in reply to emils01 [original] on Tue, 09/30/2014 - 15:50
So I called Bosch on Monday and they were well informed and helpful. They emailed me a schematic and explanation of ...
4000 PCB wiring diagram.
1. White AC line cord to white field wire.
2. Black AC line cord to thin blue wire on PCB.
3. Black motor field wire to thin black wire on PCB.
4. Black long, thick wire on PCB to red motor brush wire with push on connector.
SOURCE: The motor on my 4000 Bosch table saw burnt out
Contact Bosch for authorized repair centers near you. if you are handy with tools, you maybe able to replace the motor youself. If you happen to live in Nebraska, there is a guy in Kearney that repairs all makes of tools.
SOURCE: Bosch 4000 table saw. The saw stopped while
If you are mechanically inclined and it sounds that way do you have a volt ohms meter?? If so start at the cord and check the continuity to the brush holders. Why did you replace the field? You might have had a stuck brush or some other problem. Make sure the brushes move freely in the tubes and also look for discoloration on the commutator of the armature. Let me know what you find and I will try and help you thru the rest of it.
SOURCE: My Bosch 4000 table saw blade spins very slow.
could be bearings locking up/seizing or do you smell any burning when running indicating the armature/field are burnt from possibly overloading with a dull blade.
SOURCE: will the skil 80092 table saw stand accomodate the
Yes it will hold the Bosch 4000 with a little modification.
Testimonial: "Do you know what modifications i would have to make ? It would be of great help to know what i'm getting into before i purchase the stand!! Thanks "
