2000 Volkswagen Cabrio Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got the radio code to unlock how do I unlock radio put code in and press what?
Anonymous
Level 3:
  • Master 1,874 Answers
  • Posted on Aug 18, 2011
Anonymous
Master
Level 3:
Answers
1874
Questions
0
Helped
2166097
Points
7058
The sequence of programming for 2000 VW Cabrio radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
How do I unlock my radio on an 2016 Chevy equinox
Step 1: Look at your radio. Check and see if the code "RDS" is written on the face of the radio. If "RDS" is present, contact a GM dealership to have your radio unlocked by them.
Step 2: Check for the identification code. Press buttons 2 and 3 for 8-10 seconds. If a code does not appear on the display, you won't be able to unlock your radio in this manner.
[If that doesn't work vvv]
In order to obtain your radio unlock code, you need to find your radio's serial number. You can get the radio serial number directly from your radio.
Step 1: Turn on the ignition. Turn the key to "accessory" mode or "on" mode.
Step 2: Turn on the radio. Press the power button to turn on the radio.
If your radio displays any functions such as playing a CD, cassette, or a radio station, your radio is not locked. If no sound is heard, you may need to replace your radio unit.
If your radio is locked, "LOC" is displayed on the screen.
If "INOP" is displayed, keep your ignition on for 60 minutes with "INOP" on the display. After the hour is up, it should change to "LOC." After this you can proceed with the next step.
Step 3: Write down the code. Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 4: Note down the code. Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Now that you have your radio's serial number, you can obtain the radio unlock code from General Motors. Be ready with a pen and paper to write down your radio unlock code.
Step 1: Contact the GM radio hotline. From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 2: Enter the code. When it requests a code, enter "106010" on the keypad, followed by the pound (#) sign.
Step 3: Enter the radio serial number. You will be prompted to enter the radio serial number you have just obtained.
At the prompt, enter the number followed by the pound sign.
Step 4: Write down the radio unlock code. The prompt will read out your four-digit radio unlock code. Write it down precisely.
Now that you've obtained your Chevrolet radio unlock code, you need to enter it into your radio.
Step 1: Switch on the radio. Turn your ignition on and press the radio power button. Your radio will display "LOC."
Step 2: Enter the first two digits of the radio unlock code. Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Continue pressing the button repeatedly until the first two digits of the radio unlock code are displayed.
Step 3: Enter the last two digits of the unlock code. Press the minute button until the last two numbers of the radio unlock code are displayed.
Repeatedly press until they match the two digits you need.
Step 4: Confirm the code. When the code matches, press the AM/FM button. "SEC" will display on the radio, indicating a successful attempt to enter your radio code.
If you enter the code incorrectly eight times, the display will switch from "LOC" to "INOP." You'll need to leave the ignition on for an hour as described in Part 2 before you can retry.
Write the radio unlock code in a safe place such as in your owner's manual for future use.
Most car dealers will charge you a lot of money just to get the code for you. If you follow the right steps, you can get the code for free and be able to start listening to the radio again in just a few minutes!
How to Unlock Chevrolet Theftlock Radio
The radio is locked on a 1995 oldsmobile 88
How to Unlock a Chevy Radio Step 1: Start the vehicle and turn on the radio.
Step 2: Press and hold preset numbers 2 and 3 until a three digit code appears on the radio display. Write this code down.
Step 3: Press the AM/FM button. Your radio will display a second three digit code. Write the second code down. You will now have a six digit code.
Step 4: Call the Chevy Radio Code phone line at 1-800-537-5140.
Step 4: Enter 106010 followed by the # key to direct you to the radio code retrieval system.
Step 5: Enter the six digit code you retrieved in steps 2 and 3 followed by the * key. They must be in order. You will be given a four digit radio code. Write down the radio code.
Step 6: Start your vehicle and turn on the radio. Using the Minute and Hour buttons, enter in the four digit radio code to your stereo system. Press the AM/FM button to unlock your stereo.
How to Unlock a GM Radio Step 1: Start the vehicle and turn on the radio. The radio will display "LOC" indicating the Theftlock system is activated.
Step 2: Press and hold preset buttons 1 and 4 for ten seconds. (If you don't have a fourth preset button, press and hold presets 2 and 3.) The radio will display a three digit number. Write this number down.
Step 4: Contact your local GM Dealer and give them the six digit code. They will give you a four digit radio code.
Many dealers will give you your radio code for free, while others may charge a small fee. If your dealer is charging a larger fee, consider calling another dealer or doing a Google search for sites offering GMC Radio codes. They usually charge a small (around $10) fee.
Step 5: Start your vehicle and turn on the radio. Press the Hour button on the radio until the first two number of the code appear. Next, press the Minute button until the last two numbers of the code are displayed. Once all four digits appear, press the AM/FM button to unlock your stereo. The display will read "SEC" indicating you have successfully unlocked your radio and it is fully operational.
If radio display reads "INOP" while the vehicle is on, too many incorrect radio codes have been entered. To remove "INOP" from your display and unlock your radio, you must leave the key in the On position for one hour. Once you've retrieved your radio unlock code, write it down for future use. Your radio code will not change and having it handy will save from going from the radio code retrieval process again.
Radio displays locked
You may need the owners manual for this. The dealer can provide the steps too.
If the display says LOCKED you have to unlock it before it will accept the code. On some models you turn the radio off, press the number 6 or the select button, then turn the radio back on. Once the display is all lines or dots, you can input the code by pressing the number one button for the first digit and so on.
2answers
My 2008 chevy uplander , had to change radio (cd player not working) now radio is locked, how can I unlock it?
Try this: How to Unlock a Chevy Radio Step 1: Start the vehicle and turn on the radio.
1helpful
How do i unlock the radio
You can enter the un-lock code provided with your radio by doing the follwing:1 - Turn the ignition to ON, the radio should show LOC2 - Press MN (000 will appear on the radio display)3 - Press MN again to make the last two digits match your radio unlock code4 - Press HR to make the first 2 digits match the radio unlock code5 - Press AM-FM to unlock the radio
If the code is entered correctly the radio will display SEC
1helpful
2answers
I got an Audi TT Turbo Model 2000 The radio Bose Audi concert is giving safe on the screen and nothing else what should I click on to reset the radio so I can put the code.Thanks
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
5helpful
I need to unlock a honda accord 1995 radio
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have
FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number
MAY not be accessible without removing the radio from the vehicle.***
* TO
GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ignition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ignition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button
AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO
GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S
FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT
SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
7helpful
I NEED RADIO CODE FOR MY USE HONDA CIVIC 2003 THE NUMBER I FOUND AFTER I PRESS 1-6 WAS U2801 CAN YOU HELP ME WITH THE CODE PLEASE
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** )
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE)
-OR-
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE!
* REMOVING ERROR E3
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
Radio locked up
you have the unlock code or the gm code? here is how to enter your code
press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
