SOURCE: My Cannon Mx850 Printer has
I had the same problem after a paper jam. I removed all the paper and still had a same error. I read around the internet and ran into other Canon printers with similar problems. The error is caused by the print clean mechanism getting stuck. The suggested solution for other Canon printers also worked allowing me to fix my printer. First thing I did was turn off my printer. Second is to open the top cover allowing me access to the print cartridge area. With the power off, you can pull the printer cartridge carridge from the right of the printer to the left. Once you do that, look into the area in the right where the print carridge was and you will see two sponges in the bottom of the printer. Behind them to the left is a little mechanism that moves over the to clean them, I gently gave it a pull and it moved a little forward. I closed the printer and turned it back on. Error went away and it's working fine again.
Hope this helps!
SOURCE: Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
SOURCE: Canon MP830 Purge unit sticking
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
