Question about Technics SL-DZ1200 CD Player
My player drags in turntable mode
My player is dragging in turntable mode...in CD and sd player mode..please help!!!!!
    President:
  • 1,952 Answers
    Genius:
  • 1,665 Answers
It must be reseted. Try unplug power for ten minutes and replug. If no result check if you can remove its internal small battery and refit.
Posted on Sep 20, 2008
SOURCE:
The turntable started dragging and now the record won't finish because it stops. What's wrong ? do I need a new turntable motor? Everything else seem to be working fine thxs David
Is this a cd player or a turntable recordplayer ???
cd player that drags usually mean theres a misalignment in the tray that holds cd
turntables that drag unless they are direct drive usually need there rubber drive tires replaced or a belt what ever it has
Oct 23, 2015 | Audio Players & Recorders
Sync itunes
Launch iTunes.
Connect your media player with SanDisk memory card installed to your computer through its USB adapter.
Wait for the player's device icon to appear in the iTunes Source pane.
Drag and drop music titles from the library pane directly onto the device icon.
The music will sync onto the player's SD storage.
hope this helps
Sep 17, 2012 | SanDisk Cruzer Glide - USB flash drive -...
My mp3 does not have songs i added on it
If your talking about an mp3 player, then it depends, whether your using USB or an SD card, you did not clarify the question enough. If you are using a USB, make sure you are dragging the song onto the player, if using SD card, make sure you drag the song onto the card, then fully clicking it inside of the system.
Mar 20, 2012 | Audio Players & Recorders
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
Record player does not move
more info needed - could be that the 'belt' driving the turntable has slipped or broke - what type of player is this?
Jul 18, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Downloading
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was!
:-) Good Luck!
May 22, 2008 | GPX MW3836 MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
In turntable mode the cd's are dragging their tempo
Found a video on a web site "how to remove the platter". It's a job which does'nt need a lot of skill just great care and patience. Within the video the guy will show the senors inside the platter itself. This is wear I found a huge build up dust which I blew off with a can of air. It's not a proffensional video but I found it very easy to follow. Unfortunate for though upon putting the deck back together again I've caused more damage with my clumsy haevy handed inpatience! After looking inside the deck (as long as you have no warranty left) you will see it is not that difficult and as a tip you can disconnect the lines of flat wires as they plug into the circuit board and are not soldered in. No soldering required to fix this. The guy who made this video deserves a lot of credit due to the fact he can save many of these decks from going to the bin! If I was rich and famous I would award him an Enviromental Gong.
Oct 23, 2007 | Technics SL-DZ1200 CD Player
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
My turntable is skippin wit some drag to it!!
adjust the fucos variable of the lens use little screw look under the lens.
Sep 12, 2007 | Technics SL-DZ1200 CD Player
Technics SL-DZ1200 CD Player Logo
217 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
