SOURCE: Flashing F-9 and beeping
Check that the filter is not clogged.
Disconnect AC FIRST........******
open the bottom access panel , (3 screws on bottom lip)
remove panel
open the large filter in the center, very apparent
be prepared for water, have mops ,buckets rags, pans ready.
clean and remove all debris.
see if anything when up into the small pump area too.
spin the pump propeller and make sure it spins free.
if you find nothing but water then the main large hose in the center may be clogged, that will take some work to disengage the clips and to reinstall.
SOURCE: maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
SOURCE: flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
SOURCE: Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
