Patton U2-1487 Floor / Box Fan Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Aug 17, 2011
Anonymous
Master
Level 3:
Answers
927
Questions
0
Helped
335679
Points
2827
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Need a nob for a patton high velocity stand fan P20S 120 V-60hz just the knob as missing
if you take a picture of the post the knob will be screwed onto and bring that pic to your local hardware store hy can usually match you up with some sort of generic knob
Need replacement motor for bath exhaust fan.
Best place usually is grangers if you just need a motor. Take in motor and they can match up the exactone for you.
I have a Patton model 1010MP-1 Pedestal fan. The motor model number is 30ACP. The switch has three wires running to it (Red, Grey and Black). The switch itself is a Zing Air and has a L, 1 and 2 on the...
I was looking for this but figured it out myself. The guy wire is hot, the red goes to the low coil and the black goes to the high. So, if you wire the gray and black together, you get high as soon as you plug the fan in.
Aug 10, 2011 • Dryers
I want a new motor for the patton 20'' cvt air fan
You can generally find new motors at an electric motor shop, check the yellow pages. However they are many times more money than a new fan. Then add time and your drive to get the motor, my recommendation is purchase a new fan, cheaper in the long run.
NEED VALUE OF CAPACITOR ON MODEL 1010MP FAN. CAN'T FIND ANY INFO ON THE PART.
You can use any capacitor of value about 3.3mF to about 6.8mF with an AC voltage rating of about 230 to 250 volts.
These are the bipolar type capacitors and is generrally available at all electrical or electronic spare parts shops.
Hope this helps.
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
6helpful
Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip [email protected]
5helpful
2answers
Motor seized
I just want to know if I can purchase a NEW motor and what the cost is?
76helpful
8answers
Patton fan motor
I found something on amazon, take a look here: Emerson Fans Moving Air In Style . I hope I have helped. Cheers
Top Patton Dryers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Patton Dryer Expert? Answer questions, earn points and help others
