SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
What had changed since you last use it? Prior day? Also when last did you clean out the filters for it?
1. Drain Pump
2. Block Drain (blocked or kinked)
3. Valve Leakage
The electronic display has detected a sensor fault on the unit for the flashing you see. Check the filters and drain pump. Make sure nothing is clog also the line where the hot water goes to it. I know you said you have it under protection for 5 years and that's up right so some parts might need to be replace. If you go down to your main breaker for the unit you can trip it off and on and see if that clears it up but I you might have a serious problem with it.
Now you got 2 options.
1. Call up Viking and get an estimate of how much it will cost to repair the damage.
2. If the cost is greater than buying a brand new one then, better off getting another one then. If not then get it repaired.
SOURCE: Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
SOURCE: Latch on my Kenmore dishwasher model# 363.14582100 won't close
Sharon,
The "latch keeper" has gotten out of alignment. You'll need to adjust it.
All you'll need is a phillips screwdriver to fix this. Open the door and look at the "latch keeper" (it's not on the door, but on the frame). It's the thing that the door lock/latch grabs on to when you try to lock the door. There are 2 screws holding it in place. Loosen these, pull the keeper toward you a bit and tighten the screws to lock it in. Now try your door.
This may take several attempts to get it just right, because you want the door closing tight enough so as not to allow a water leak and loose enough for you to close it easily.
If you have any questions, post back and I'll try to explain in better detail.
SG
