SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
SOURCE: APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
SOURCE: My Powercom UPS overload
remove all loads, unplug it, turn it off, wait 1 minute, plug it in, turn it on, apply loads. if this does not solve the problem, replace it.
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
SOURCE: APC Back UPS RS-1000 Overload LED with beeping sound after on.
this indicates you have too many things plugged into it.
