Toshiba 36A50 36" TV Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons and it disappears for about 10 seconds, then reappears. ow can I get rid of this? Thanks for your help. Mike
Chi Chu
Level 3:
  • Toshiba Master 8,457 Answers
  • Posted on Aug 17, 2011
Chi Chu
Toshiba Master
Level 3:
Answers
8457
Questions
0
Helped
2822820
Points
26282
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
1helpful
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Channel setup without remote
Hi I attached product manual link for your Emerson EWC19T4.
I believe that you can find solution.
pdfretriever com
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
1helpful
2answers
Remote was lost. Tried to adjust the station and now I cannot get the TV to go to channel 3 so converter box will not work. Itied a universal remote did not work. Help
I assume, that the TV is skipping chan 3 when using the Channel buttons on the TV.
You can try 2 things.. First see if your converter box will use chn 4. Usually there will be a very small switch on the back of the box marked with a small 3 on one side and 4 on the other. If so, use that till you get a replacement remote.
If that's not an option, you can also, Re-scan the channels on the TV. to find all available chn for memory.. BUT FIRST making sure that the converter box is on and working.
The TV shuold then detect that there is a signal on chn 3 and make it available to the chn buttons on the set.
You will have to use the menu buttons on the set to do this.. Hopefully one of the buttons is the menu call up, then you use vol or chn buttons to navigate it.
Hope this helps
How do i put it on channel three manually?
If the remote to your box can be paired with your tv then you should be able to fix this problem simply by pairing digi remote with tv and while in tv mode on remote, hit the input button. That should change tv back to cable/antenna setting so that you may access channel 3. Hope this was helpful.
2helpful
I need to manually turn the TV to ch 3 and cannot because it skips it from 4 to 2.
Enter "3" or "03" on the remote and press OK/Enter.  If the channel-skip feature is set on for Channel 3 you cannot get to it using the up/down buttons.  Go to the setup menu to disable the channel-skip for Channel 3 if you want to tune it with up/down buttons.  If you have no remote you should be able to access the menu from buttons on the front of the TV. (They may be inside a door or panel.)
2helpful
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
