If your Maytag washing machine is agitating during the spin cycle, it could be due to a few different issues. Here are some possible causes:
Defective Transmission: The transmission in the washing machine is responsible for shifting the agitator and the drum between the spin and agitation cycles. If the transmission is defective, it may not be able to engage or disengage the agitator properly, causing it to spin during the spin cycle.
Worn Drive Belt: The drive belt connects the motor to the transmission and helps to control the speed and direction of the agitator and drum. If the belt is worn or damaged, it may not be able to properly control the agitator, causing it to spin during the spin cycle.
Malfunctioning Clutch: The clutch in the washing machine helps to regulate the spin and agitation cycles. If the clutch is not functioning properly, it may not be able to disengage the agitator during the spin cycle, causing it to spin along with the drum.
Faulty Timer: The timer controls the various cycles and functions of the washing machine, including the spin and agitation cycles. If the timer is faulty, it may not be able to properly sequence the cycles, causing the agitator to spin during the spin cycle.
It's best to have a professional technician inspect and diagnose the issue to determine the exact cause and the necessary repairs.
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
