Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I dropped my camera and now it is saying lens error. I have already tried turning it on while holding down the shutter, it is not working.
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Oct 13, 2011
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1215701
Points
16135
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sony cybershot camera fell and lens is stuck
The lens may be out of position, or there could be dirt/dust in the lens mechanism. You could try some of the following suggestions:
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
Sep 07, 2014 • Cameras
Upon powering on the Power Shot A1100 IS , Cannon log appears, then a bling byte sounds, then a series of six beeps and the Lens Error, Restart Camera message displays. The lens is retraced and will not...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Think it's time that you might have to weigh the options of either considering professional repair, or trying the more risky steps in the link.
My camera kodak easyshare c813 say lens error when i turn it on and it dont let me take a picture it say lens error 111,0,0,0 then it changes to lens error 221,0,0,0
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Camera is stuck with the lense popped out, but the shutter closed. It stays in the same position whether off or on. The screen says "error 3"
Hello
Error 3, is a lens error. Here is something you can try.
Regards
Andrea
Lens shutter problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
5helpful
Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
1helpful
Lens Error
Hey Joy_2008,
A lens error usually means something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. You could also try placing the camera on a flat surface with the lens pointed up. While holding the shutter button in turn on the camera. What this sometimes does is force the lens to move before the camera shuts down, and when the lens moves hopefully it will dislodge whatever is stuck. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Nikon L11 lens error
Hey meghanB,
One thing you could try is placing the camera on a flat surface with the lens pointed upwards and press and hold the shutter button, while doing this turn the camera on. When you do this the camera should try to focus which sometimes will force the lens back on track. If this doesn't work you should have it looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out to be looked at. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
1helpful
2answers
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
3answers
Lens error
Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
