Question about Xact Communication XS034 Boombox
Boombox does not maintain connection to radio
Greetings, I recently purchased a Xact Stream Jockey II radio and its corresponding boombox. When the radio is placed into the boombox, after a few seconds the radio shuts off. We have discovered that this is corrected by pushing down on the receiver and that the boombox appears to lose the connection to it during play time
  • Anonymous Nov 30, 2007
    I have had the same problem,and have tried everything. You can send it to place in georgia and they will replace it for
    Problem Solver:
  • 13 Answers
Here is the fix,Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife the radio will now play without any problem!
Posted on May 11, 2014
    Scholar:
  • 124 Answers
If the problem can be "fixed" by pushing down the reciever, it must be caused by some sort of loose contacts or wiring. there's a good chance that tightning some screw will solve this problem. if you have basic electronic skills you can open the unit and check for any loose screw or wire.
Posted on Feb 15, 2006
  • Paul Norman May 11, 2014
    I don't recommend taking this unit apart due to the fact that it was designed to discourage it
SOURCE:
What is the price of a XTR1 xactStream [Jockey Sirius Radio & An Antenna
These show up on e-bay all the time; I suggest you look there. Regards.
Jul 08, 2014 | Xact Communication XTR1 SIRIUS Radio...
How can I get a new AC adapter that is compatible with the Xact X32X-2 Radio?
The only thing you can do is contact the company that makes this product. It might be cheaper to purchase a new pair of radios complete with chargers.
Jul 01, 2014 | Xact Communication X32X-2 2-Way Radio
My xact boombox just stops
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knifeyour radio will now play without holding it
Mar 26, 2013 | Xact Communication XS034 Boombox
Xact XTR2 will not turn on
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
Jun 17, 2012 | Sirius Satellite Radio XACT XTR2 Satellite...
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Xact stream jockey 11 sirius boombox xs034
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife your radio will now play without holding it
Aug 23, 2008 | Xact Communication XS034 Boombox
Powers on and off with batteries
i would say you have bad luck with boomboxes try getting an mp3 player. j/k
May 01, 2007 | Xact Communication Xact XS027 Portable...
Sirius problem
I have the same problem, when I contact Xact (through e-mail) they said that the unit would have to be replaced. They didn't say that THEY would replace it, but said it had to be replaced.
Mar 28, 2007 | Xact Communication XTR1 SIRIUS Radio...
Xact Communication XS034 Boombox Logo
170 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
