I have a universal remote control need code for my orion tv
SOURCE: I need a code to program my universal remote to an orion tv
i cant get my tv off aux mode no matter what i try
SOURCE: remote code orion tv/vcr # tvcr0950bw
I had a bugger of a time trying to solve this exact same problem. I went through 3 universal remotes before I found a winner. Using the Jensen Surf Series SC-340 I managed to figure out the code for the vcr to be 687. This is not listed in the manual that I looked up for the remote, probably because the remote was made in 1997 while the tv/vcr is 1998. After trying the ~30 codes in the manual I set the remote to auto scan for the code. After 30min scanning for the tv code I switched over to scan for the vcr code. Three minutes later I get the code and that "Oh yeah. Who got this bad boy to work? You did! That's right!" kinda feeling. I hope this helps.
TLDR: I got a Jensen Surf Series SC-340 Universal Remote to work with the tvcr0950bw using the code 687 on the vcr.
SOURCE: have 8 yr old Orion tv-new remote control for
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
I have a universal remote and do not remeber the password code for the V-chip . Please let me know what to do to change the password.
The original remote for my Orion 1924 broke a long time ago, I have spend nearly $100 on universal remotes and none of the codes listed in the books, nor does the Auto Search or Manual Code search, I don't know if this is some kind of feature Orion came up with to make you have to buy a remote from them, but im getting very frustrated! The next time I purchase I television I can guarntee it will not have the Orion name on it and I intend to tell everyone i know or see interesting in televisions not to purchase one either. If anyone could help I would greatly appreciate it.
We have a 1998 Orion 13' t.v. and have the remote. It was working but we moved it to our house where we have Dish and the t.v. will only cut on but will not change channels with the remote we do not a manuel. Can we down load on some where or do we need to do something else? HELP
I have a REM 100 Magnavox Unviersal remote control and an Orion TV. The code 135 liste3d in the booklet does not work nor did the automatic mode. Is there any other codes for Orion TV set?
