SOURCE: Multiple Telephone System Compatibility Issues
I most cases it should not matter that you have different phones to 1 phone line. You should make sure that all the phones are running off the main feed box for your property and not off each other. Check that all the wires are connected in each port and that the phone line running between the phone itself and the feed box does not exceed 50 feet because this can cause the phone to echo or not work at all.
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
SOURCE: rings only twice then goes to answering service
JUST RAISE THE AMOUNT OF SECONDS BEFORE THE BUILT IN ANSWERING SERVICE KICKS IN...
SOURCE: LG Chocolate, De-activate Voice Mail?
There isn't a way to disable voicemail cause it automatically fowards the call.
