This seems to be an battery issue. You can try to replace the battery
All-Battery.com
Thank you
SOURCE: dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
SOURCE: Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
SOURCE: dell inspiron 6000 battery light is orange
remove the battery and insert again. if it continues then you will have to check the power source perhaps current it not enough for charging, if it continues then you will have to get a new battery
Testimonial: "Thanks for the help. That is what I expected."
SOURCE: Dell Inspiron 1525 monitor blinking with and
there is a Inverter board Inside of LCD screan is defective, needs to be replaced. send to repair
SOURCE: I have a dell inspiron 1525 the battery light was ...
It means the battery charging.if you want to buy new on, you can see one here: canada: <a href="http://www.buy-battery.ca/laptop-batteries.php/1+replacementfordell+inspiron--1525">dell inspiron 1525 battery</a>
usa:<a href="http://www.all-batteries-shop.com/compare-batteries.php/1-128528-replacementfordell-inspiron-1525-battery">dell inspiron 1525 battery</a>
