Turn off the printer,wait 10 minutes,than turn it on. If not good yet,open the top of the printer.Look for small shooter that holds the laser.Open,and force the laser out into the center of tracking craddle.After you move the laser,unplug the printer for few minutes.Then plug it back in.
Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
Flip open the top of the printer.
Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
After you move the laser, unplug the printer for a few minutes.
Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
Solution 2:
Solution 3:
If the same error occurs, it's necessary to contact a service representative.
aser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms. Error Code: E100 0000
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps. 1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following. 1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges. If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Laser scanner unit error.
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms. Error Code: E100 0000
