We are having a client server application running behind sonicwall tz170. We have the server in the other office. Both the offices are connected thru 2Mbps MAN. A client PC has to run the application exe file to connect to the server. After working on the application for some time, the user gets a error ('Communicaiton link failure') and the application needs to be restarted and the work gets lost. we have created access rules for the users with all the services on and we have set the TCP connection timeout to 180 mins.
Please help
SOURCE: Printer Setup & Support Call 1-805-225-6690 We will Help to Fix issue
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
SOURCE: sonicwall client won't connect to the internet
The default VPN policy rules prevent LAN access, also known as split-tunneling, since this creates a security risk (the ability of the VPN session to be hijacked or compromised through a covert channel).
If you are not the system admin, you need to talk to your system admin. If you are the system admin, then you need to review the documentation with respect to
http://www.sonicwall.com/us/support/kb.asp?kbsk=policy+allow+lan
SOURCE: Anybody, please help! I need it! Sonicwall issues
There are many reasons for your problem, make sure you have the Computer and Register PC are in the switch section of the Sonicwall - not in the WAN port. The router should allow traffic to flow by default. Check the Operating system and turn off any firewalls, the router will take care of that.
SOURCE: how to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
