its the safety solenoid. thinks the gas is on, they have them fitted so if the gas is flowing and don't heat the switch it will keep sparking till it does. you will need a gas engineer to sort this out. as there is seals that if you dont put back on right you cancause a gas leak.
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
You're gas burner has an electronic ignition that you're hearing. Sometimes they can get gunked up and become sticky. If you have been using the stovetop regularly and this problem suddenly appeared, we can assume that the power grounding and polarity are correct. If this is all true, then an igniter or igniters are either wet or dirty. Unplug the electricity and thoroughly clean the burner pieces and specifically the igniters (little separate cylinder next to each burner) with a sponge or other non-abrasive dishrag and hot soapy water. Make sure all the burners and igniters are completley dry, plug unit back into electric outlet. If problem persists,call an authorized repair person as you may need 1 or more igniters replaced.
Good luck
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
