Ours was doing it so I cleaned the air filter now it's stopped doing it alls ok
This problem is usually caused by an improperly installed water collection bucket or the float valve inside the top of the bucket is broken or stuck in the DOWN position.
To troubleshoot this, turn the unit OFF & unplug it. Remove he bucket, check the float valve's position. If it stuck in the UP position, jiggle the handle to make it return to the DOWN position. This will also allow you to determine if the float is broken. If all this checks out, reinstall the bucket "squarely" from top to bottom into the bucket holder. It must make contact with the bucket safety removal switch on the back wall of the holder. When installed properly, the bottom of the bucket will not tilt down at all. Plug the unit in and turn it ON. If everything was done correctly, the unit should start within a few seconds.
Hope this helps you to troubleshoot and solve the problem. Thnanks for choosing FixYa.
