this is a bios level error, you should still be able to run the system. this code is something you get when you hit F12 and run the diagnostics? or is this a blue screen error? you are probably going to need to boot to F2 (setup) then hit "Alt e" Alt F then Alt B the system will beep on the alt f but that's ok once this is done hit esc, save changes and reboot and see if you still get the error
Hi It seems that the Hard Disk is disconnected from it's connectors It needs to be fixed and installed correctly. To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly. If it's difficult to you, go to technician to do that.
Possible cause Graphic Card Test Failed, Mother Failed, if your Notebook is under Warranty it is better to bring it to Service Warranty Center. or you can repair it by checking the mother board or video card. This problem occurred when your graphic or mother board is failed to start or initiate during start up.
screen display on my Dell Inspiron 1545 with MS XP OS- Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
