Question about Dictaphone Walkabout 5210 Digital Voice Recorder
My dictaphone m5215 is faulty and I cannot transfer my recording to my computer. is there another way of getting the recording off this unit that is dysfunctional at the moment?
  • 207 Answers
Hello
Make sure your unit is on off position when you connect the unit to pc
Posted on Oct 19, 2011
SOURCE:
I have the m5215 which I used w/ windows. I now have a Mac. It does not seem to work with mac. Any advice on how to download dict and then transfer?
I am not fammiliar with Mac but I beleive if the device is connected and the Mac does not show it as a removable drive, it will not work. The only digital recorders that I know are Mac compatible are the Olympus models. A DS2400 would be the closest to the 5215.
Nov 18, 2011 | Audio Players & Recorders
I need a handsfree headset recording device for the dictaphone 3750
Hello this is a great solution
http://www.tvps.com/Products/Nuance-Dictaphone-0421-C-Phone-Hands-Free-Overhead-Headset-with-Boom-Microphone---New__ECS-CMH.aspx if your unit is already modified for hands free with the 3.5 extenal jack mic input if not you also can send your unit to modified Send an email to service@tvps.com or call (805) 644-9525
Jun 08, 2011 | Dictaphone 3750 Desktop Cassette...
Will Dictaphone Write work in Windows 7?
Hello yes it is. Walkabout Transfer Software, version 1.5.2, is required for the WA5220 portable. Backwards-compatible with WA5210/5215(DS) portables. Windows 7 compatible. For Dictaphone Digital portables and Trancription kits you can go to http://www.tvps.com/Departments/Digital-Dictation/Digital-Portable-Recorders/Dictaphone.aspx?sortorder=4&page=1
Apr 19, 2011 | Dictaphone Walkabout 5210 Digital Voice...
Which transfer program for dictaphone m5220 works with windows 7?
You can use either Walkabout Transfer or Walkabout Write found here:
https://isupport.nuance.com/OA_HTML/csksxvm.jsp?nSetNumber=13097
Also, if you connect the portable via USB to your PC, it'll connect just like a USB memory stick and you can use Windows Explorer to transfer your dictation from the 'DSS' folder.
Mar 01, 2011 | Dictaphone Walkabout 5220
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Aug 24, 2010 | Dictaphone 2750 Desktop Cassette...
Dictaphone use for Medical Transcription
You'll need a digital recorder (Dictaphone makes one - a Walkabout Model 5220). Transferring a recording from an analog (tape) machine to a PC requires a patch cord to hook it up to your PC, then some sort of software to record it while it's playing back.
May 12, 2010 | Dictaphone 1243 Handheld Cassette Voice...
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Apr 05, 2010 | Dictaphone 2750 Desktop Cassette...
Dictaphone does not turn on
There is a small hole in the back of the unit. This activates the firmware update. My experiense is someone pushed this in with a pin and caused the switch to be stuck. You can disassemble the unit and use a pin to pry the bubble switch up or off. This switch is only needed to update the firmware which can also be done thre software so is not needed.
Oct 15, 2006 | Philips Pocket Memo 9450 VC
Dictaphone Walkabout 5210 Digital Voice Recorder Logo
209 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
