SOURCE: display flickers, no image is
jglendenning, If not into soldering irons, solder, meters, and electronic repair of "switch-mode-power-supplys/cold-cathode-fluorescent-lamp ballast-circuits" then trade for new unit! Retrevo .com lists K717s as time to retire unit. Before you do anything check out the longer and more useful video clips at YOUTUBE that deal with "lcd monitor disassembly" and "lcd monitor repair" FYI so you at least know what is inside a typical desktop CCFL back-lit LCD monitor. 99% use same basic design and principle of operation no matter what brand of unit you have or will purchase in future!!! Hope this helped some. 12fixlouie
SOURCE: My monitor worked great for the period of 5 years
Bad caps can look normal but it they can have high ESR, but you should take some voltage readings first, it should have 5vdc and 12~16vdc when the monitor is plugged in but not turn on.
Post pictures of the caps also, many people told me the caps look OK until I see the pictures and they turn out to be bad. You need cap meter taht can read capacitance and ESR.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
