Homelite ZR10926 16 Chain Saw Logo
Posted on Aug 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil-gas ratio - Homelite ZR10926 16 Chain Saw
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Aug 16, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801754
Points
33142
2answers
What is troy built tb 32 EC gas oil mix ratio?
Hi anon, the usual ratio for most 2 stroke engines is 40:1. The 1 being two stroke oil
Jul 30, 2014 • Garden
What is the oil gas ratio
The oil gas ratio is the proportionate amount of 2 stroke engine oil mixed with gasoline to be used as a fuel for the smaller (mostly) commonly used 2 cycle engines on chainsaws and weedtrimmers. Here is a oil gas ratio chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
May 17, 2011 • Garden
What is the petrol to oil ratio in a two stroke mixture
Ratios range by machine and manufacturer from about 32:1 up to 50:1. 40:1 is most common.
32:1 4oz. oil/US gallon gas
40:1 3.2 oz oil/US gallon gas
50:1 2.56 oz oil/US gallon gas
Here is a chart with many different ratios:
http://www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
Oct 28, 2010 • Garden
2helpful
GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
1helpful
What is the ratio of gas to oil?
You can run it with a 50:1 ratio. 1 gal gas to 2.56 oz. two stroke oil.
1helpful
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
5helpful
Craftsman chainsaw ps00376 2.0 cubic inch oil/gas ratio
Hi rbv1222,
40:1 is the ratio.
40 parts Gas to 1 part oil.
3.2 oz of oil per gal gas.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Nov 08, 2008 • Garden
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
