SOURCE: service error 5C10
http://software.canon-europe.com/products/0010326.asp
uninstall the software and download the latest software from the above side and install it
SOURCE: I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
SOURCE: I'm getting an error 5c10 on my printer. how do i
Try to reset the printer by turning it off and then back on. (Unplugging the power and data cables often gets a better system reset.) If that doesn't work, the printer may need professional repair. If it is under warranty, contact Canon. Otherwise you will need to decide if it is worth repairing (with a ~$50 charge just to diagnose the problem).
I hope this helps.
SOURCE: Error message : service error 5c10 on a canon
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
or
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
SOURCE: service error 5c10
This error is a message indicating print head/ink failure on the printer.
I would try the following 2 things:
1. replace the ink cartridges/print heads. test to see if the problem is fixed.
2. If this does not solve the issue, you may need to either send it to the manufacturer for repairs (if under warranty), send it to a local repair person to service- or look for a new printer to buy (which may actually save you money).
