Sony Walkman NWZ-W202 MP3 Player Logo
Barry Pearce Posted on Jan 12, 2018
Ive had my zappin w202 MP3 player for about 2 years now and ive had no troubles with it at all, until last Wednesday, when my PC stopped recognizing it(unknown device) and i dont know why. So all i get now is a constant pop up of a warning that is not been recognized and its driving me up the wall.
5 Related Answers
issy2
Mohamed Ismail
  • 462 Answers
  • Posted on Aug 02, 2008
SOURCE: Sony Walkman - Digital Music Player NWD-B105F
try to do a update from sony site thats the last option..
Anonymous
  • Posted on Mar 22, 2009
SOURCE: mp3 player will not work "usb device not recognized"
is not work io devices error
Anonymous
  • 3 Answers
  • Posted on Nov 18, 2009
SOURCE: NWZ-W202 is not recognized by computer with window
i had the same problem, after trying everything i and helping friends could think of, i just wiped my entire pc reformat n started from scratch, once i did that, before installing anything at all, i plugged her in and she workd straight away and has continued to work. HAPPY DAYS
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Feb 10, 2010
I would try another computer if that did not work the unit is what we called bricked, now you could go to sony.com and see if they can help you to try to get thing back in order please do try my solution first if it does not work the unit is defective.
Thanks and please do use the thumbs to rate this solution and advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 12 Answers
  • Posted on May 16, 2010
SOURCE: My nwz-s545 is not working properly i have had it
On the back of the unit, there should be a small reset button. Pushing and holding that button for about 5 - 10 seconds should reset the unit.
If that doesn't work, you may want to read WarMaiden.org's solution to getting the computer to recognize the Walkman...it may work for you.
1helpful
NWZ-W202 is not recognized by computer with window vista home operating system when it is plugged in usb port
2answers
Music won't play in order it is listed
it is probably in suffle mode, try and go into the options menu in the actual Mp3 player and you will have to look for suffle or something uncheck it or turn it off or whatever the option is on the screen. but it is possible to find the manual online just look for it
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
1helpful
2answers
Sansa e250r works but will not format
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
Sandisk e270 !!!!!!!!!!!!!!
hi sir..
if ur are formated the memory card..
1. memory card may be corrupted.
2. try to restore the factory settings
a) by tool>setting>phone>general> restore factory setting's or other option like install. thank u sir..
please fix it.
Waited for my ipod to come back and it never did!
well call up apple, they should have given you a ticket number
if not, then you out of luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
My mp3 wont turn on,how do i fix it, its an ilo2gb
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
3answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
