Question about Watches
I'v first time bought a digital watch fastrack 4052,n i don know how to set d timer,alarm or time settings..will u plz help me.. Thanks
  • 30 Answers
Look for a mode button then you can scroll to the setting you which to change. once you are there look for an adjust (or similar) button. you hold that down until something flashes or it allows you to change the desired setting. also refer to your user manual if the watch came with one
Posted on Aug 15, 2011
  • Snehal Yeole
    Snehal Yeole Mar 05, 2014
    I tried a lot but not able to set time on watch. Please help me.
  • Snehal Yeole
    After clicking on Mode I cannot see anything like setting. I can change the numbers but I am not able to save the changes. Also, I can not stop running for some time. Please help me.
6ya staff
SOURCE:
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
I just bought my Iron Man watch a couple of weeks ago and all of a sudden my alarms/timer won't work. The indiglo light flashes but there is no sound or beep. I tried resetting it by pressing all the...
check the caseback of your watch, hold it upright turn it around. look at the markings, if the markings is doesnt match the upright postion you have to open it then put the caseback on its proper position because the part that is beeps is attached on the caseback and the machine has small spring to connect power on it. i hope i had been helped you.
Sep 06, 2011 | Timex Sports Ironman Triathlon 100-Lap...
I am trying to get out of army time for my digital wrist watch, and there is an alarm that keeps coming off that I don't know how to stop. I'm not sure of the brand...i bought it at Wal Mart about...
Your watch should have a "mode" button (often at 8 o'clock) and this enters the settings menu so that you can change them. keep pressing the mode button until you reach the setting you want to change.
You should be able to find a setting that says something like "24". Experiment with the remaining buttons to change the setting. The display should change to "12".
Press the mode button to find the setting for the alarm (Often abbreviated to "AL" or "ALM"?).Again experiment with the buttons to either remove the alarm or or change it form "ON" to "OFF".
Changing the values of the setting is often done by pressing the 4 O'clock button but if this does not work, try the one at 2 O'clock.
Jun 03, 2011 | Timex Watches
I want user guide for my fastrack digital watches
Go to their web site (www.fastrack.in/Products/Products.aspx) and at the bottom right of the page is a flashing sign "digital watch manuals" .
Click on this and choose your manual.
Feb 11, 2010 | Watches
Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
Jan 03, 2010 | Watches
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
http://www.skagen.com/service/watchInstructions.fx
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Watches Logo
445 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
