Paragon 1015-00RS Indoor Multi Operation Timer Logo
Posted on Aug 15, 2011
The relay on my Paragon 1015-00RS timer has gone bad,, where can a purchase another one
A
Anonymous
You won't be able to find parts for that timer unless e-bay is selling used timer.
Patriot supply sells new timer, Aug 2011:
http://www.patriot-supply.com/products/manufacturer_detail.cfm?manu_id=191
Paragon is no longer making timers and parts except defrost timers.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic crossover timer is 120Volt T1975, which sells for less and has replaceable 156T1978A trippers and WG733 clock motor. Relay is not replaceable part.
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour/t1900%20t1970%20series.aspx
1helpful
I have the Paragon 4001-00 timer. The timer seems to be working okay as far as time and trippers are tripping however it doesnt seem to be engaging our secutiy door lock for the night. Could the conrt
Does the manual override lever move back and forth as trippers pass? If NO, then trippers are bad
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://www.amazon.com/dp/B00441YVCO/?tag=waterheaterti-20
120 Volt timer.
When timer is ON, test across terminals 2 and 3 for 120 Volt
If 2 and 3 show 120 volt, then timer is delivering power on schedule. Look for loose connections. Loose wire nuts.
If 2 and 3 do not show 120 Volt, then timer has failed.
Suggest buy T101 as replacement for durability and generic replacement parts.
http://waterheatertimer.org/Buy-T100-series-timers.html
Crossover wiring from Paragon 4001-00 to Intermatic T101
Paragon 1 to Intermatic 1, Paragon 2 to Intermatic 2, paragon 3 to Intermatic A
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
The clock on my paragon 4004-71m is not working
1) Clock motor has gone bad, but replacement clock motors are no longer made.
Copy following link for Paragon resources:
2) Paragon is not making parts or replacement motors.
4007-41 is 240Volt timer, replace timer with Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Crossover wiring from Paragon 4004-71 to Intermatic T104:
Paragon 3 to Intermatic 4
Paragon 4 to Intermatic 3
Intermatic terminal A is generally not used for 240Volt
4) Add a comment if needed
1helpful
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
4003-0s clock wont count does turn to show time or swicth on lights
1) If timer dial is not rotating, then the clock motor has gone bad.
New paragon clock motors are not sold anywhere I know about.
2) If dial rotates on time, but trippers don't work, then buy new X2772 trippers.
3) Buy new 120Volt 4003-00 timer at Southside for $86:
http://www.southsidecontrol.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3823.html
4) BuildingHVAC sells 4003-00 timer for $56.00
http://www.buildinghvac.com/acatalog/Products_Paragon_4003_0_24_Hour_Time_Clock_4003_00_3709.html
The micro switch is bad and i need a new one...where can this be purchased?
1) Paragon is no longer making timers and parts except defrost timers.
You posted under JW-30-00 series cycle timer, which is not a defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
2) JW timers are still sold on internet. Some Paragon timers are still being sold, and other manufacturers will continue making various Paragon products under new names.
3) Intermatic cross reference shows CT1000 is replacement for JW-30-20
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
http://www.intermatic.com/~/media/files/intermatic/products/sell%20sheets/time%20switches/ct1000%20sell%20sheet.ashx
4) Tork makes the ACT series cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
I need a wiring diagram for a three phase paragon timer model number 8145-20.
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
I need to get some trippers for my paragon hot water heater timer i believe it is a 4004-20....any suggestions where i might can purchase them....thanks bill
4000 series Paragon timer uses X2772 tripper
To check your model:
Midnight electric sells X2772 tripper
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_X2772.html
That being said,
According to e-mail I got from Paragon last month, Paragon is no longer making timers or timer parts. Except for defrost timers. 4000 series is not a defrost timer.
This explains why some sellers of these trippers are asking $50 or more for $3 pair of trippers.
To change your timer to Intermatic.
Refer to Intermatic cross reference:
Top Paragon Hardware & Accessories Experts
john h
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
